Naviate Accelerate is also part of the following releases:
Naviate Accelerate September Release 2025
Release news for Naviate Accelerate. Highlights includes new download from MySymetri, updates to Sheet Collections, Publish, View and Sheets from Settings, CAD Tracker and more.
Check for updates
Updated Symetri login
Updated Symetri licensing
If you have rights to manage licenses on My Symetri there is now an option to create a license file including Single user licenses that you can copy to machine not connected to internet.
A zip-file is generated and downloaded by the browser. Extract the included license files and copy them to the %appdata%\Symetri\Licensing folder on the machine you want to use off-line when you are logged in as the user specified when creating the license file.
Sheet Collections
Added Sheet Collection support to a variety of features from Manage Sheets tab.
Revit 2025 introduces the Sheet Collection feature, allowing users to assign sheets within a model into flexible groupings. Sheet Collection parameters are now available for compatible view types in Revit, alongside existing sheet parameters. This update enables multiple sheets to share identical sheet numbers, provided they belong to different Sheet Collections.
This means that several Naviate features that interact with sheets have been updated to support Sheet Collections. These features include:
- Create Sheets
- Create Empty Sheets
- Edit Sheet Parameters
- Place Views
- Align Views
- Revision Manager
- View and Sheet from Settings
- Legend Manager
- Print Set Manager
- View Filter Manager
- Edit Parameter Values
Publish
Updated IFC Export to support Category Mapping templates.
Revit 2025 introduced Category Mapping templates for IFC Export. We updated IFC Export in Publish feature to support these templates.
Added Scope Box option when creating, naming and numbering sheets.
You can now create sheets for different Scope Boxes per level. The Scope Box name is incorporated into both the Sheet Naming Convention and the Sheet Numbering Convention. When adding sheets to the list, you can select not only View Sets and Levels but also one or more Scope Boxes.
CAD Tracker
Added possibility to open a CAD file or CAD file location from UI.
Now you can open CAD files and file locations directly from CAD Tracker. To do this, simply right click on a linked CAD file and choose one of the available options.
- Family Browser - Fixed errors when selecting a directory containing folder shortcuts.
- Publish – There is a known bug in Publish when upgrading projects from Revit 2021 to 2025. Saved settings in Publish are not converted correctly and data loss may occur. A workaround is to first upgrade to Revit 2022-24 and then to 2025.
