Naviate Accelerate May release 2025.2
Release Naviate Accelerate. Highlights includes two new features Style Sweep and Norkart Import. Updates to Unhode Elements, Fabrication Parts, Update Schemas, Changes for solving conflicts between projects and What's New pop-up.
What's New Pop-up
NEW! Style Sweep - Manage Object Styles
This new feature provides efficient management of imported Object Styles within your Revit projects.
Key Functionality
- Inspect Style Usage: Gain insight into how imported Object Styles are being used throughout your project. This includes:
- All Families loaded in the project
- In-place Families
- View Templates
- Imports
- Informed Decision-Making: Leverage usage information to make strategic decisions about your Object Styles.
- Style Management:
- Delete Unused Styles: Safely remove Object Styles that are not currently in use within the project.
- Purge Unused Styles: Quickly eliminate all unused Object Styles.
- Merge Styles: Merge Object Styles of the same category into a target style.
- Duplicate Identification: Easily identify potential duplicate styles through intuitive color-coding within the interface.
Benefits
- Improved project performance by reducing unnecessary Object Styles.
- Enhanced project organization and standardization.
- Simplified management of imported CAD and other data.
- Cleaner and more efficient Revit models.
NEW! Norkart Import - Norwegian Standard only
Naviate Accelerate now includes the Norkart Import feature, enabling you to import highly detailed maps directly into your Revit projects as a comprehensive base for your design work.
Key Functionality
- Web Solution Access: Provides direct access to the Norkart web platform for purchasing relevant map data.
- Help Documentation: Easily access dedicated help documentation to guide you through the Norkart Import workflow.
- Import Functionality: Offers a specific function for importing downloaded map data from Norkart seamlessly into your Revit environment.
Unhide Elements - Choose what to unhide
The Unhide Elements command has been enhanced to provide greater control over which hidden elements are revealed in a view. Previously, initiating the "Unhide Elements" command would automatically reveal all categories hidden by Element within that view. With this improvement, upon running the "Unhide Elements" command, users are now presented with a categorized list of the hidden elements. This allows you to selectively Unhide Categories. You can choose categories you wish to remain hidden. These settings will be saved per user.
Filter Elements - Exlude Grouped Elements
Now when using Filter Elements feature to select elements or save selections, you will be able to exclude elements that are in groups. This is simply done by activating a toggle button.
Fabrication Parts Support
New Fabrication parts categories are now supported in various Naviate Accelerate features. Support is added for following categories:
- MEP Ancillary Framing - 24 and 25 only
- MEP Fabrication Containment
- MEP Fabrication Ductwork
- MEP Fabrication Ductwork Stiffeners - 24 and 25 only
- MEP Fabrication Hangers
- MEP Fabrication Pipework
Updated features are:
- 3D Zones tools
- Filter Elements
- Live Selection
- Color Elements
- Combine Parameters
Tree-views are also updated in various features to show Assemblies Sheets separately.
Update Schemas
A new tool has been introduced to help users effectively resolve potential data conflicts that may arise when opening multiple Revit projects within a single session.
Depending on the configured settings for various Naviate features, a "Data Conflict" warning might appear when multiple projects are open simultaneously in Revit. Failure to address these conflicts before saving could lead to permanent data loss.
Schemas causing conflicts will be updated when the user saves new setting, or they can all be updated in a single operation using Update Schemas tool from Accelerate’s Manage Project tab. This enables you to efficiently convert an entire project if you are encountering data conflict issues.
Update Schemas does not change loadable Families.
- Parameter Transfer – Added a scroll bar when the list of the parameters is long.
- Publish – IFC Export – Added support for Ceiling Grids (2025 only), Exporting bars in uniform rebar as separate IFC entities (2025 only), supporting links as separate file (2024 and 2025 only) and 2D Plan View elements (2024 and 2025 only).
- Edit Parameter Values – Fixed a bug when decimal places where shown incorrectly for custom decimals option.
- Combine Parameter Values – Improved checking and unchecking of items in the list.
