Naviate Accelerate is also part of the following releases:
Naviate Accelerate June Release 2024.5.1
Release news for Naviate Accelerate. Highlights includes the new feature Remove Schemas and fixes.
New! Remove Schemas
Many Revit plugins use document’s extensible storage to store settings for a variety of features. These settings are referred to as Schemas. Now you can remove these unwanted settings (schemas). Schemas are removed only from the open document and not from loadable Families.
- Edit Parameter Values: The width of the category selection dropdown is now adjusted dynamically so that longer category names are fully displayed and easily readable.
- Find and Replace: Fixed errors when replacing parameters without any value.
- Room Elevations: Removed country standard restrictions so that the feature is no longer available for US standard only.
- View Template Manager: Improved the column filtering functionality to support the application of multiple filters simultaneously.
- Place Views: Improved multi selection in Views tree-view using Shift button.
- Advanced Parameter Manager: Improved warning message for duplicate parameters to display correct parameter information.
