Naviate Accelerate December Release 2022.1.6
Updates in Naviate Accelerate. Highlights include Licensing and fixes.
Changes is available in version 2022.1.6
To be able to update all Naviate applications to version 2022.1.6 , you need to manually download and install the update from our download page. Remember to update Naviate Help and Naviate Accelerate as well. All installed applications must be updated to 22.1.6. Except Naviate Rebar Extension that has no update anymore. Find more information here.
Licensing
Update to support coming changes in license portal. NOTE! All installed application needs to be updated to 22.1.6
We have changed to use the same version of licensing as we use for Naviate 2023; there are no major differences in functionality, but it will support some coming changes in the license portal.
Note! You must update all Naviate for Revit applications to 2022.1.6 at the same time. If not, some applications may not start, or you might not be able to get a license to use them. Naviate Accelerate and Help needs to be updated individually.
You need to manually download and install the update from our download page.
- Combine Parameters: Fixed issue with Phases for categories supporting To/From Room
- BCF Manager: Fixed issue with missing information when reading some files in 2.1 format
- Starting Naviate: Added a message if needed Arial (Regular) Font is missing
