Naviate 2020.3 & 2019.6 for Civil 3D
Naviate 2020.3 & 2019.6 for Civil 3D are released!
Naviate 2020.3 and 2019.6 are released and ready for download on Naviate.com!
For a full list of what is included see Release Notes here! In March we will also hold three webinars where we go through all the news, sign up below.
News in Naviate 2020.3 for Civil 3D
March 9 | 14:00 CET | Is held in English
Naviate 2020.3 & 2019.6 for Civil 3D is released, you will get to know all the new and updated functionalities, such as:
- Create Min/Max surface from two surface
- Naviate Surface Volumes command now creates cut Solid/Mesh from several surfaces layers
- Stepped Profile, a new command to create a profile line that works with the updated Retaining Wall subassembly
- Quantify Curb stones, a tool to quantify and verify curb lines in your drawing Create Property Set and attach Properties from CSV and Attributes
- Filter functionality in the Property Palette
- Scripted Assembly Updates
- Pressure Pipe Support in Naviate Pipe Subassemblies
- News in Road Subassemblies
Retaining Wall Design & Curb Quantification
March 16 | 14:00 CET | Is held in English
In Naviate 2020.3 for Civil 3D, there are new functions for Retaining Walls & Curb Stones, such as:
- Calculate Curb Stone (SWE: Kantsten) length/quantity of different radiuses from polylines or alignments.
- Retaining Wall Design using Naviate function Stepped Profile, to create top and bottom profile in fixed lengths and heights
- Use new version of Naviate Retaining Wall subassemblies to create a Corridor where e.g. the Foot Length automatically adjusts with the Wall Height
- Create Corridor Solids in the fixed lengths and heights
- Add properties to the solids from CSV-file with manufacturer data
Assembly Management with Naviate
March 23 | 14:00 CET | Is held in Swedish
Naviates assembly functionalities give project managers tools to distribute and update assemblies across large projects, we will show how to:
- Export your Assembly to save and re-use assemblies between projects
- Create a library of Assemblies or a Master-Assembly-dwg for your Project
- Verify version of Assemblies in your consumer drawing
- Update drawings when the Assembly version changes
- Script-update Assemblies and Corridors in several drawings
