Naviate Accelerate provides enhanced functionality for all Revit users. Whatever industry you work in, Accelerate will help you improve your BIM workflows by offering expanded capabilities in Revit and reducing manual tasks.
            In Naviate Accelerate you will find all the common specifications and features for your Naviate for Revit. With your chosen discipline on top you will have access to the Naviate best suited for your work tasks and project planning.
Naviate Accelerate contains all the features found across the AEC industries, from collaboration, productivity and documentation. With best practice workflows and task management like Family Browser, Filter Elements, Sheet Manager, and Edit Parameters to mention a few.
Filter any object based on type or instance parameter value from the entire project. You can combine filters and save them for reuse. If it's in Revit you can filter it.
Edit and view instance or type parameter values in a table form. You can select any category, all parameters are available. Non editable parameters can be filtered. You can view and edit schedules, sort your list and copy/paste values.
Automatically write a number sequence on specified element types. You can number by selecting objects or by spline. Prefix and suffixes can also be includes. Auto-swap will swap numbers from objects that need unique numbering. You can also inherit the number from a selected object.
Colour any category by type or instance parameter values. You can override element graphics in view with colours and show and select elements in the properties. Create multiple filters based on your selection criteria, your filters will override current view template.
This is a gold star of a feature - you will save so much time you can spend on better tasks. Create multiple sheets with your requirements to sheet parameters, sheet revisions, legend views, scale and sheet format in one place. There's less room for errors and no manual work.
Print documents and export to DWG or IFC files. You can easily reuse the same settings the next time you need to publish the same views or sheets.
