Naviate Accelerate
Naviate Accelerate offer features and solutions to enhance your BIM workflow. It can be used on top of your Revit and is not industry specific.
Naviate Architecture is fully integrated into the Revit platform and enhances the collaboration possibilities offered by BIM.
Bimfire is made for Fire Engineers to work directly in Revit. It enables you to transmit data from your Fire Safety models to the other collaborators in a building project.
Automate daylight area ratio checking of your BIM model for optimising design decisions on indoor lighting, windows and other elements for better work and living areas.
Revit with Naviate Electrical allows you to work collaborative and optimised in a building information modelling (BIM) environment. Electrical designs can be created simultaneously in both 3D and 2D, a big advantage when satisfying increasing demands and mandates for BIM delivery.
Advanced modeling and fabrication commands to increase productivity and revenue for VDC designers, detailers, and contractors.
Design ventilation and piping systems in full 3D. Smooth calculations through data exchange and integrated functionality.
Drive efficiency with modeling and parameters for MEP engineers and designers.
Automate the process of generating reinforcement for elements like beams, columns and walls.
Automate the process of generating reinforcement for elements like beams, columns and piles.
Easy to use IFC data and workflow. Create models that only contain the information needed for a specific task.
Get an environment fully customised to the needs of landscape architects – including content, tools and workflow. The template files contain features, symbols and line styles as well as plants and trees.
Naviate Structure provides you with a large library of completed object types. In addition, there are complete standard profiles and foundations designed to be quickly and easily customised to suit the project you are going to work with.
Make smart material selections to minimise the carbon footprint in your designs. You have direct access to updated Environmental Product Declarations (EPDs) and values for your selected country and regions.
