Receive data
- Section diagrams
- Civil 3D COGO points
- Property Set Data on COGO points
Naviate Geotech is an addon to Civil 3D to import, present and analyse Geotechnical data from Field Manager or from CSV files. Naviate Geotech can then visualise the data in 3D or in plan and profile. The solution will be available in Sweden and Norway with the first release.
The data from Field Manager is presented as section diagrams, Civil 3D Cogo points and Property Set Data on Cogo Points. This can then be used to create stratum, solids and profile diagrams with hatching. There is also methods for adding virtual boreholes and editing boreholes to make sure that the data is presentable.
Field Manager is developed by NGI Digital, the Norwegian Geotechnical Institute’s digital innovation department. It is an open and cloud-based platform for geotechnical ground survey data. Field Manager support the planning, collection, processing, storage, quality assurance and availability of your valuable geotechnical data.
Naviate can communicate with Field Manager from within the Civil 3D environment and download data from your projects within Field Manager with the click of a button. Naviate Geotech works with Civil 3Ds template which gives the user all the flexibility with Styles that Civil 3D gives.
Right now we only have a release preview available. You can contact us on this email if you would like to test it out. Once we go live with the first full release, you can download a trial. Want to be informed once that is available? Register in the interest form on this page.
The first version will only support the Swedish and Norwegian market.
