Symetri Technology
AI built for BIM teams. Starting with where you work
We're adding AI directly into the tools your team already uses. It understands your workflows, plans the steps, gets your approval, and does the work. Inside Revit, inside Naviate. No new software to learn.
Revit & BIM
MEP & Architecture
Model QA
Secure & Auditable
Human oversight
Customers & Users
Less clicking. More building.
You already know Revit. Our AI learns your workflows and handles the repetitive parts like parameter edits, clash checks, documentation and model QA, while you stay in control and approve every action before it happens.
  • Describe what you need in plain language - the agent plans and executes
  • Review and approve the plan before anything changes in your model
  • Every action is logged - reversible and visible to your team
  • Work inside Revit, in the Naviate panel you already have
  • No new interface to learn, just type what you want
100+
Naviate commands exposed as AI tools. The workflows you already rely on, now accessible via plain language
Instead of clicking through ribbon commands, I type what I need and review the plan. The model stays mine, I just skip the repetitive part.
How it works
Simple for users. Powerful underneath.
You describe it
Type what you need in plain language inside Revit. No commands, no menus to dig through.
AI plans, you approve
The agent breaks the plan into steps, shows the plan and waits for your go-ahead before anything changes.
Work done and logged
Steps are executed in Revit. Every action is recorded with context, timestamps, and is reversible
Human oversight is not optional, it's built in
Write operations require explicit approval. All actions are logged and reversible. The AI is a capable assistant, not an autonomous actor.
Real workflows. Real outcomes.
Where we start
Model QA and Health
"Find walls not on a grid, flag warnings, and create a QA report."
Query - Flag - Report
The agent scans the model against your standards, flags non-compliant elements, tags them in the model, and generates a structured report - all in one prompt. Previously required a manual checklist and element-by-element review.
Documentation
"Create a sheet set for all Level 1 plans with standard title blocks."
Views - Sheets - PDF
Sheet creation, view placement, title block population, and PDF export in one workflow. Replaces a manual sheet-by-sheet process that grows proportionally with project size.
Bulk Parameter Management
"Find all doors without fire ratings and set to 60 min where room type is corridor."
Filter - Condition - Edit
Multi-condition parameter updates across hundreds of elements with your approval before any values change. One natural language instruction applies logic across the entire model scope.
Project Setup and Planning
"Set up levels, grids, and view templates from the project brief."
Levels - Grids - Templates
One of our first workflow focus areas. The agent reads project parameters and sets up the Revit environment; levels, grids, view templates, and sheets, so the design team can start working immediately.
Roadmap
What we're building
First out is Revit and your daily workflows. Then we will expand across platforms and teams.
Targets
What we're measuring
25%
Beta Adoption Target
of beta users completing AI-assisted workflows weekly.
90%
Total Accuracy Target
the agent selects the correct function for a given natural language instruction.
80%
Approval Rate Target
of agent-proposed plans approved by the user, a signal that the agent is getting it right.
5
Beta Customers
Enterprise customers in production by end of pilot.
Customers first
We're validating before we build
Workflow priority is driven by customer conversations. Each product team identifies their top use cases during discovery. We build what real teams actually need.
Our differentiation
Specialized agents for specific workflows
Our domain expertise and customer relationships, not generic AI, are the competitive drivers. Depth beats breadth here.
Platforms
Connected tools. One platform.
In Revit
Naviate AI Agent
Natural language automation inside Revit. Powered by the Naviate API; 100+ domain-specific commands exposed as AI tools. Separate installer, separate license, AI permissions built in from day one.
MEP + ARCHITECTURE
Platform
Naviate API / Nebula API
The foundation layer; 100+ Naviate commands exposed as a structured API, then wrapped as MCP (Model Context Protocol) tools. Any AI client can connect and orchestrate these tools. CTC tools already available as MCP.
MCP ready
How we work together
Technology + Expertise + Customers
Product & Technology
We build the platform around our customers’ needs; AI agents, APIs, MCP servers, and supporting infrastructure that enable real value in their daily work. We turn the Naviate workflows you rely on most into AI-powered tools, continuously learning from how they’re used so we can refine, improve, and deliver even better experiences over time.
Customer Discovery & Workflow Insights
We start with you to understand your workflows, challenges, and where you spend the most time. Through ongoing conversations and early prototype testing, we work together to validate what truly adds value. Your feedback directly shapes what we build next, prioritizing the areas where you experience the most friction so we can deliver meaningful improvements faster.
Consulting Expertise, Powered by You
We turn your domain expertise into scalable impact. By capturing your deep understanding of workflows, we help transform your knowledge into intelligent agents that support real project work. In the next phase, we’ll be able to create and share agents built from your experience, contributing to a growing ecosystem of proven, discipline-specific solutions that you can easily adopt and benefit from.
Get involved
Join the beta. Shape what we build.
We're running customer validations now. Reach out if you want to take part in the journey.
Download a free trial
Naviate Intelligence Discovery Journey
Join our Naviate Intelligence Discovery Journey to help shape the scope of our AI solutions.
I would like to book a meeting
