Naviate Architecture
Naviate Architecture seamlessly integrates with the Revit platform, enhancing the collaboration features of BIM. With standardized concepts for detail levels, material definitions, and naming conventions, it ensures a smoother and more efficient design process for your projects.
Customised for architects
Revit allows you to work in a complete building information model (BIM). Naviate Architecture adds the advantages and possibilities to make you more efficient when working with Revit and BIM. During the development, we work closely with customer reference groups. They play an important role when it comes to designing the project template files and supporting applications that form the basis of Naviate Architecture. Pre-sets and standard configurations are well thought through, designed to provide optimal working methodologies and a smoother working experience.
Save time
Optimize workflows
Quicker and easier when everything works together
Naviate Architecture is fully integrated into the Revit platform and enhances the collaboration possibilities offered by BIM. This naturally applies to the objects included for designing in 2D and 3D. Concepts like the level of detail, material definitions and nomenclature follow common standards.
Full support for collaboration
Naviate Architecture fully supports the overall vision and collaboration opportunities offered by BIM. This also applies to how functions and symbols in the module interact as for communication with other Naviate modules and interaction with other disciplines in a project.
Explore Naviate Architecture
Door Tool
Identify all doors in your project to manage and document parameter values such as: swing direction, room number, levels and department.
Zone Tools
Create sheet and plan views rapidly by zone in your current project.
Filter Elements
Find and select exactly the elements you are interested in by category, type, parameter information etc.
Align Walls
Correct walls that are slightly off axis. You can align one or more walls to be perpendicular or orthographic to another wall.
Room Data
Automatically enrich the room parameters with the net perimeter values, window and door areas.
Room Drawings
All required views are automatically placed on a pre-configured sheet for any number of rooms you select.
Naviate Blog
Symetri e-learning
